Введение
If a car door suddenly will not close, it may be due to a stuck car door latch. Sometimes a latch may become stuck if someone accidentally knocked it into a locked position while the door was open. On many newer cars, simply pulling the interior or exterior door handle may reset the latch, but in cases where that is not enough, this guide will describe how to manually reset the latch.
Выберете то, что вам нужно
On the car door that will not close, examine the door latch located near the handle on the side of the door.
While the exterior door handle is being pulled, push the screwdriver against the left leg of the latch.
Use the screwdriver to push the latch upwards into the final unlocked position.
Close the car door to ensure the latch has been properly reset.
Thank GOD for google! I didn’t know what to do. Very informative.
Du bist mein Held!
10 участников успешно повторили данное руководство.
14 Комментариев
Thanks a lot, you have saved me from one !&&* of a problem!
This helped me so much!! Thank you!!!
Perfect. So simple. Excellent advice once again from iFixit. Thank you.
Thank you so much! I figured it out because of this post!
I love this solution. It literally just saved me. Thank you soo much.
Was washing me uncle’s car when i just decided to fiddle with the inside lock with the key, who knew it'd make me spend 30 minutes out in the finger nibbling cold trying to use the same key to unfiddle what i just fiddled. Just happened to open google to pull an exterior wachama-call-it and then refiddle that key.
Thank you so much. It was so easy. In my mind, I was already thinking I was going to have to call a tow truck, have it towed, and get a rental car. The directions are clear and concise. It took all of 4 seconds after I read the instructions.
Not really helpful if you have to manually do this literally every time you want to get in and out of the car, which is the situation I’m stuck in right now…
hi....use a metal nail file if you have one or something similar ( or the tip of a key.... the manual lock type) if possible....i know not ideal but it's better than nothing if you're stuck somewhere
wjoh5v9 -
Selbes problem aber andersherum…Tür lässt sich nicht öffnen wegen verschobenen Schloss…lösung?
Helped a lot. My brother did something to the latch and it got stuck. If I didn’t find this, he would’ve been crying 🤣 Thank you so much for the help!
But what if it does it every time?? What’s the part called? Can someone change it themselves or does it have to go to a shop. I can change a clutch, brakes, spark plugs all the filters and I can read and follow directions. Plus Kia has this awesome online manual year make model specific unlike rhe old books so I’m thinking I got this and if not dukes of hazard style here we come. Probably break a leg trying to jump out the window of my sorento though.
Tür ist im geschlossenen Zustand blockiert
Hubert schaub - Ответить
