How to Repair a Stuck Trailer Jack
Выберете то, что вам нужно
  1. How to Repair a Stuck Trailer Jack, How to Repair a Stuck Trailer Jack: шаг 1, изображение 1 из 1
    • Remove the trailer jack from trailer.
    • Use a 19mm box end wrench to remove the 19mm hex head bolt that secures the jack to the trailer.
    • Slide the jack off the trailer to remove.
    • Be sure to safely support the trailer before removing (With a vehicle or jack stands).
  2. How to Repair a Stuck Trailer Jack: шаг 2, изображение 1 из 1
    • Remove the nut and bolt that secures the handle to the jack.
    • Use two half-inch box end wrenches to remove the half-inch bolt and nut.
    • Slide the handle upward after removing the nut and bolt to remove the handle.
    • Set the handle aside.
    • Screw the jack to the most extended spot the jack will go.
  3. How to Repair a Stuck Trailer Jack: шаг 3, изображение 1 из 1
    • Lift the spacer or washer upward.
    • Set the washer aside.
  4. How to Repair a Stuck Trailer Jack: шаг 4, изображение 1 из 1
    • Turn the jack upside down and use a hammer to gently slide the upper assembly off the lower assembly.
    • Set the upper assembly aside.
  5. How to Repair a Stuck Trailer Jack: шаг 5, изображение 1 из 1
    • Begin to remove the rust and corrosion using a die-grinder and steel wire wheel.
  6. How to Repair a Stuck Trailer Jack: шаг 6, изображение 1 из 1
    • Apply grease or anti-seize lubricant to the screw assembly.
    • Screw the screw assembly to full extension and shortest extension to ensure lubricant reaches every section of the screw assembly.
  7. How to Repair a Stuck Trailer Jack: шаг 7, изображение 1 из 1
    • Remove rust and corrosion from the upper and lower assemblies of the jack using a die-grinder and sanding pad.
  8. How to Repair a Stuck Trailer Jack: шаг 8, изображение 1 из 1
    • Paint the upper and lower assemblies for prevention of future rust and corrosion.
  9. How to Repair a Stuck Trailer Jack: шаг 9, изображение 1 из 1
    • During re-assembly, align the notch on the upper assembly to the grove on the lower assembly.
  10. How to Repair a Stuck Trailer Jack: шаг 10, изображение 1 из 1
    • Use a hammer to force the upper assembly over the lower assembly.
    • Be sure to align the grove and notch of the assemblies.
  11. How to Repair a Stuck Trailer Jack: шаг 11, изображение 1 из 1
    • Install the washer and the jack handle over the stud of the jack.
    • Insert the bolt through the handle and the hole located on the stud.
  12. How to Repair a Stuck Trailer Jack: шаг 12, изображение 1 из 1
    • Install the jack to the trailer and test for correct operation.
Заключение
3 участников успешно повторили данное руководство.
Cody Gearin
Участник с: 03/25/20
336 Репутация
1 руководство автора
Команда
University of Memphis, Team S5-G10, Willis Spring 2020 Участник University of Memphis, Team S5-G10, Willis Spring 2020
UM-WILLIS-S20S5G10
1 член
Автор 2 руководств
Один комментарий
Thank you, very helpful. our tongue jack was a bit different looking but the principles were all the same, and with the help of this guide we got it fixed.
Loren Turner - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 113
За последние 30 дней: 477
За всё время: 19,764
