Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Examine the damaged seam in your garment, checking for tears and removing any loose threads.
Flatten out the garment around the torn seam, and align the fabric where the seam used to be.
Pin the two layers together. Be sure to catch only the two layers of fabric you wish to sew back together.
Open the garment as much as possible, laying the seam flat.
Check your alignment and make sure the two edges of your fabric line up.
Put the garment in the machine, starting a few inches before the torn seam to overlap with the stitches.
Drop the presser foot. Align the first line of stitches with the needle.
Sew along the first line of stitches, removing the pins before you get to them.
When you come to the end of the row of stitches, engage the backstitch function of your machine. Backstitching prevents the seam from unraveling.
Depress the pedal slowly. Sew two or three stitches backwards. Release the pedal and disengage the backstitch function.
After you've completely sewn over the torn seam, clip the threads and free the garment from the machine.
Some clothes have two rows of stitching, If your garment does, reposition it in the sewing machine. Drop the needle into the second line of stitches at about where you began sewing your previous seam.
Repeat steps 3-7 of this guide to resew the second line of stitches.
If your garment only has a single line of stitches, skip this step and proceed to the next step.
Check that your stitches are straight and secure.
Admire your work.
2 участников успешно повторили данное руководство.
