Введение
Over the years, dust, dirt and poor treatment may damage your trophy. This guide will show you how to fix one step-by-step. Trophies are a way of keeping in mind the efforts and sacrifices you've made in a particular sport or hobby. Simple tools that you probably have at home were used to repair this trophy. So if you want to remember some of your achievements and treasure them, I invite you to have fun fixing your most precious trophies.
Выберете то, что вам нужно
Put the cylindrical tube on the small threaded rod of the cup.
Turn to the right until you tighten it completely.
Place the longest threaded rod on the opposite side of the cylindrical tube and twist again to the right until it is tight.
Insert the nut into the hub of the 3/8 drive ratchet wrench.
Use the 3/8 inch ratchet wrench to secure the nut at the bottom of the trophy. Turn the nut clockwise until it is fully secure.
Wait some time (approximately 30 minutes) until the pieces have dried completely.
And your done!!
This work will be completed when all the pieces are tight and without coming off. Remember not to touch the glued pieces too much to avoid breaking them again. I hope you had fun arranging a good memory.
