Введение
Improper storage, exposure to heat, and cats can lead to warped vinyl. Warped vinyl can lead to a wobbly sounding rendition of your favorite song. Fortunately, warped records can often be fixed, so you can be back to rockin' and rollin' in no time. You'll need two sheets of glass larger than your album, but small enough to fit in your oven. Heavier or thicker glass tends to work best.
Once you've finished your repair, be sure to store your vinyl properly, vertically and out of the heat, to prevent any future warping.
Инструменты
Запчасти
No parts specified.
  1. Pull your record out of its case, and make sure it is nice and clean. If your record is dirty, you'll want to clean it before starting. Place your clean record in the center of one of the glass panels.
    • Pull your record out of its case, and make sure it is nice and clean.
    • If your record is dirty, you'll want to clean it before starting.
    • Place your clean record in the center of one of the glass panels.
  2. Gently set the second glass panel on top of the record. Gently set the second glass panel on top of the record.
    • Gently set the second glass panel on top of the record.
  3. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  4. Preheat the oven to warm, or 175 degrees Fahrenheit (or 80 Celsius). Preheat the oven to warm, or 175 degrees Fahrenheit (or 80 Celsius).
    • Preheat the oven to warm, or 175 degrees Fahrenheit (or 80 Celsius).
  5. Glass can shatter when it experiences temperature shock. Be sure that your glass is room temperature or slightly warm before putting it in the oven, so that it doesn't go from very cold to warm too quickly. Slide your record, sandwiched between the two panels of glass, into the oven. Stay with your record and watch it. If you smell anything funny or hear any strange noises, remove your record from the oven.
    • Glass can shatter when it experiences temperature shock. Be sure that your glass is room temperature or slightly warm before putting it in the oven, so that it doesn't go from very cold to warm too quickly.
    • Slide your record, sandwiched between the two panels of glass, into the oven.
    • Stay with your record and watch it. If you smell anything funny or hear any strange noises, remove your record from the oven.
    • Warm your record in the oven for 2 or 3 minutes.
    • Leaving your record in the oven for longer may melt your record.
  6. Using oven mitts, pull the glass and record assembly out of the oven.
    • Using oven mitts, pull the glass and record assembly out of the oven.
    • Remember that glass can shatter with temperature shock. Do not set your hot glass on a cold granite or tile countertop, or it may shatter!
    • Set the glass on a room temperature table or counter. To protect your surface, place the glass on a potholder or a towel.
  7. Weight the glass with heavy books or another flat, heavy object. Leave the record under the weight of the glass and books until it cools completely. When the record is cool, remove it from the glass panels.
    • Weight the glass with heavy books or another flat, heavy object.
    • Leave the record under the weight of the glass and books until it cools completely.
    • When the record is cool, remove it from the glass panels.
Заключение
Test your vinyl out. If there is still a warp you can repeat the process heating it for just a little longer and weighting it with a heavier object.
19 участников успешно повторили данное руководство.
Brittany McCrigler
Участник с: 05.03.2012
81 434 Репутация
Автор 132 руководств
Команда
iFixit Member of iFixit
Community
104 членов
Автор 8 369 руководств
Комментариев: 10
And for the rest of the world: Step 3 is 80 °C (Celsius).
werner - Ответить
just the same process to fix the graphic card of a macbook pro :-D
(Y) great!
Johan Miller - Ответить
Try this: Get two 1/2" x 12" x 12" polished marble floor tiles. Bathe (the tiles) in hot tap water until heated through. Place record in poly sleeve between the two tiles. Place weights on top - the more the better. Wait for tiles to cool. Repeat as necessary.
BooFaar - Ответить
BTW - Be sure to dry the tiles after heating.
BooFaar - Ответить
When I was a kid, I watched my Mom fix a warped record one time by putting it between the plates of glass and setting it in direct sunlight for about 10 minutes. That worked as well.
OriginalSpins - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 43
За 7 дней: 256
За 30 дней: 1,319
За всё время: 71,777
