How to Repair a Warped LP Record
Выберете то, что вам нужно
  1. How to Repair a Warped LP Record, How to Repair a Warped LP Record: шаг 1, изображение 1 из 3 How to Repair a Warped LP Record, How to Repair a Warped LP Record: шаг 1, изображение 2 из 3 How to Repair a Warped LP Record, How to Repair a Warped LP Record: шаг 1, изображение 3 из 3
    • Pull your record out of its case, and make sure it is nice and clean.
    • If your record is dirty, you'll want to clean it before starting.
    • Place your clean record in the center of one of the glass panels.
  2. How to Repair a Warped LP Record: шаг 2, изображение 1 из 2 How to Repair a Warped LP Record: шаг 2, изображение 2 из 2
    • Gently set the second glass panel on top of the record.
  3. How to Repair a Warped LP Record: шаг 3, изображение 1 из 3 How to Repair a Warped LP Record: шаг 3, изображение 2 из 3 How to Repair a Warped LP Record: шаг 3, изображение 3 из 3
    • Preheat the oven to warm, or 175 degrees Fahrenheit (or 80 Celsius).
  4. How to Repair a Warped LP Record: шаг 4, изображение 1 из 3 How to Repair a Warped LP Record: шаг 4, изображение 2 из 3 How to Repair a Warped LP Record: шаг 4, изображение 3 из 3
    • Glass can shatter when it experiences temperature shock. Be sure that your glass is room temperature or slightly warm before putting it in the oven, so that it doesn't go from very cold to warm too quickly.
    • Slide your record, sandwiched between the two panels of glass, into the oven.
    • Stay with your record and watch it. If you smell anything funny or hear any strange noises, remove your record from the oven.
    • Warm your record in the oven for 2 or 3 minutes.
    • Leaving your record in the oven for longer may melt your record.
    excellent instructions . I tried to give you the extra points but once I signed in I couldn't find a spot to click on!
    cynthiast.amand - Ответить
  5. How to Repair a Warped LP Record: шаг 5, изображение 1 из 1
    • Using oven mitts, pull the glass and record assembly out of the oven.
    • Remember that glass can shatter with temperature shock. Do not set your hot glass on a cold granite or tile countertop, or it may shatter!
    • Set the glass on a room temperature table or counter. To protect your surface, place the glass on a potholder or a towel.
  6. How to Repair a Warped LP Record: шаг 6, изображение 1 из 3 How to Repair a Warped LP Record: шаг 6, изображение 2 из 3 How to Repair a Warped LP Record: шаг 6, изображение 3 из 3
    • Weight the glass with heavy books or another flat, heavy object.
    • Leave the record under the weight of the glass and books until it cools completely.
    • When the record is cool, remove it from the glass panels.
    j’ai réussi à dévoiler un vinyl neuf que je viens de recevoir par blueNote »rolling » de Truffaz. J’ai d’abord essayé 3 min à 80 degrés C, le vinyl étant toujours voilé, je l’ai laissé 6 min et là c’est parfait. Pour un précédent cas avec un autre vinyl j’avais fait couper 4 disques de verre de 10 mm d’épaisseur au format 33t en securit, j’ai posé le vinyl nettoyé aux ultra sons sur le premier disque, j’ai posé les 3 autres disques de verre dessus, mis au four, et voilà une belle galette bien récupérée.
    vmarc17107 - Ответить
Заключение
Test your vinyl out. If there is still a warp you can repeat the process heating it for just a little longer and weighting it with a heavier object.
39 участников успешно повторили данное руководство.
Brittany McCrigler
Участник с: 03/05/12
89 014 Репутация
Автор 131 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
12 Комментариев
just the same process to fix the graphic card of a macbook pro :-D
(Y) great!
Johan Miller - Ответить
Try this: Get two 1/2" x 12" x 12" polished marble floor tiles. Bathe (the tiles) in hot tap water until heated through. Place record in poly sleeve between the two tiles. Place weights on top - the more the better. Wait for tiles to cool. Repeat as necessary.
BooFaar - Ответить
BTW - Be sure to dry the tiles after heating.
BooFaar - Ответить
When I was a kid, I watched my Mom fix a warped record one time by putting it between the plates of glass and setting it in direct sunlight for about 10 minutes. That worked as well.
OriginalSpins - Ответить
Would sheets of stainless steel work? I don't have access to glass sheets.
Carlos Sanchez - Ответить
I used 2 pieces of glass first time 170 degrees 3 minutes did not do the job then I try 4 minutes a bit better then I went for 5 minutes after that I put 4 heavy books for weight on the glass for 1 hour.The record came out perfect.
stan.bade007 - Ответить
Now, if only there was an easy way to fix scratches…
Tim Wasson - Ответить
I came here because the new Fleetwood Mac albums (50 Years Don’t Stop Collection)I received today are warped… Got a kick out of seeing Rumours. Luckily, however, my Rumours original press is nice and straight. Gonna return/replace my box set… But, thanks for the tutorial. It’ll surely come in handy for some of my other vinyls.
Brian O'Connor - Ответить
Where did you get those glass panes from
Robert - Ответить
For the two glass panes you can use two sliding mirror from a bathroom/laundry wall cabinet..
chrisnelson242 - Ответить
Many ovens, including mine, will not regulate properly down to 80C…..The lowest setting on mine is 120C….Far too hot, as I found out!
The temperature can be changed however by slowly moving the knob around between the lowest setting and off ..(gas oven).
Use a temperature probe in the oven, attached to a temperature or multi-meter and stay and adjust the oven to the right temperature for the necessary 3 - 5 minutes with the record in the oven.
Remember it is better to underdo (can redo) than overdo (It’s toast) for obvious reasons…Good luck!
Добавить комментарий
Просмотр статистики:
За последние 24часов: 29
За последние 7 дней: 193
За последние 30 дней: 686
За всё время: 158,048
