How to Repair a Wooden Picture Frame
Выберете то, что вам нужно
  1. How to Repair a Wooden Picture Frame, How to Repair a Wooden Picture Frame: шаг 1, изображение 1 из 1
    • Pull back the metal clips that hold the frame, you may use the pliers to pull them back if needed.
    • Remove the back of the frame and find a safe spot for it. You will need it at the end of the guide to put it back together.
    • If the glass seem's to be cracked, handle the frame gently and wear gloves to prevent injury
  2. How to Repair a Wooden Picture Frame: шаг 2, изображение 1 из 1
    • After clamps are lifted, carefully remove glass out of the frame. You may use the pliers for this step to lift the clamps
    • If glass is broken as mentioned in the first step, carefully remove it with safety gloves to prevent from injury
  3. How to Repair a Wooden Picture Frame: шаг 3, изображение 1 из 1
    • Begin to pull apart any loose joints that may be embedded in the frame with the needle nose pliers
  4. How to Repair a Wooden Picture Frame: шаг 4, изображение 1 из 1
    • Begin to sand off the finish with the sandpaper if the frame appears to be scratched or damaged in any way
    • Sand by hand, this appears to be the easiest way to approach the wood, going along with the grain.
    • Continue to sand out the scratches until smooth as you remove the finish.
  5. How to Repair a Wooden Picture Frame: шаг 5, изображение 1 из 1
    • If you proceeded to sand the frame, or not, restoring the color of the wood gives it a great finish and shine.
    • Take your paint brush and lightly dip it into the stain, covering all parts of the frame. Proceed to let sit for 1 hour until dry.
  6. How to Repair a Wooden Picture Frame: шаг 6, изображение 1 из 1
    • Using carpenter glue, glue the joint(s) back together and apply pressure when pressing sides together using your hands.
    • You may use clamps on the joints if repairing all four sides of the frame, for better structure.
    • Let glue sit to dry overnight.
  7. How to Repair a Wooden Picture Frame: шаг 7, изображение 1 из 1
    • After letting sit overnight, your glue should be dry and your frame should be as good as new!
    • Be sure to replace any glass that may had been broken when the frame collapsed.
    • Measure any dimensions with a tape measure to get an exact measurement of the glass, then cut with a glass cuter.
    • Insert new glass onto frame, and push down side clamps.
Заключение
Еще один человек закончил это руководство.
Kaley Anderson
Участник с: 01/21/19
175 Репутация
1 руководство автора
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 29
За последние 30 дней: 143
За всё время: 10,128
