Введение
A damaged dresser base can be dangerous in a household. This repair guide takes users through the steps of how to repair the bottom of a dresser.
Выберете то, что вам нужно
Using a pair of pliers, remove the existing staples from the bottom of the dresser.
Remove the piece of hardboard and realign it so that it is in the position you desire.
Using the tape measure, measure the distance between the two sides of the dresser frame and then cut a beam of wood to fit these specifications.
To reassemble your dresser, follow these instructions in reverse order.
Еще один человек закончил это руководство.
