Введение
This guide will demonstrate how to re-attach a broken toe strap of a fabric sandal. This guide will begin by presenting the tools you will need to conduct this repair. Then the guide will detail the steps you will follow to repair your sandal.
These instructions are necessary to prevent excess clothing waste and save you money.
This guide requires you to handle a sharp razor blade and super glue. Be sure to keep your fingers away from these tools to prevent injury.
Выберете то, что вам нужно
Draw a rectangle on the bottom of the sandal that centers the hole of the toe strap.
Slice through three connecting sides at the bottom of the rectangle using a box cutter.
Insert a toothpick into the bottom slit.
Use the toothpick as a lever to wedge open the flap.
Close the sole flap.
Press the flap down until it is even with the sole of the sandal.
Tighten the trigger clamp by squeezing the trigger.
Leave the trigger clamp on the sandal to dry overnight.
Pour rubbing alcohol onto a paper towel.
Rub the paper towel over the shoe to remove pencil marks and excess glue.
If you properly follow the instructions in this guide, your sandal will be repaired to a lasting, wearable condition.
