Введение
If you need to repair the buttons on your Logitech Pebble M350/M355 mouse, follow this guide. This guide will show you how to disassemble the mouse to reach the scroll wheel and buttons and apply a small amount of lubricant to them.
Many users of this mouse have encountered a problem where the buttons eventually stop working. Since this isn't ideal for a device you use every day, the purpose of our guide is to provide a simple solution for this common problem.
Выберете то, что вам нужно
Use your hands to remove the magnetic top panel of the mouse.
Remove the USB adaptor in the small rectangular hole on the lower right corner.
Remove the battery.
Use a Phillips #000 screwdriver to remove one screw holding the inner panel in place.
Gently wipe the metal axle where the scroll wheel is mounted with a small amount of 3-in-1 oil.
Repeat for the left and right click buttons.
Еще один человек закончил это руководство.
2 Комментариев
I didn't even disassemble (unscrew) my pebble. Just applied a drop of mineral oil to the button and it did help a lot! Thanks!
