Введение
It is common for plastic wiper blades to oxidize during seasonal temperature changes, and a pair of new wiper blades will help improve visibility during different weather conditions.
Follow this guide to replace the windshield wipers on your Audi A4 2009-2016 (B8) model. In this guide, we are using Michelin Wiper Blades purchased from Costco. If you are purchasing parts from another store, make sure that it fits the Audi wiper blades connector.
Выберете то, что вам нужно
Go inside your car and press the “CAR” button on the control panel.
Scroll down using the control wheel to "Windshield wipers".
Press the center button on the control wheel to select the option.
Press the center button on the control wheel to edit the service position.
In the drop-down menu, switch it from "off" to "on" by scrolling with the control wheel and pressing the center button.
Pinch the bottom of the connector to release the cover and remove the top-lock connector.
Install the new "Top Lock-Narrow" connector onto the base connector.
Press down until it clicks into place.
Install the blade into the blade arm, sliding the new wiper blades down until it clicks and is locked into place.
Install the new connector cover by pinching the base of the connector.
Close the connector cover on both sides of the wiper blades.
Remove the yellow wiper protector on both blades.
Put the wiper back on the windshield
Test the new wiper blades before you hit the road for safety.
Еще один человек закончил это руководство.
