How to Replace Asus Transformer Pad TF103C Headphone Jack
Выберете то, что вам нужно
  1. How to Replace Asus Transformer Pad TF103C Headphone Jack, Headphone Jack: шаг 1, изображение 1 из 1
    • Turn the power off.
    • Insert the plastic opening tool between the top and bottom covers of the laptop. The two covers are attached all along the outside of the laptop.
    • Use a thin screwdriver if you don't have an opening tool.
    • Gently pull upwards and carefully pry open the bottom and top covers.
  2. How to Replace Asus Transformer Pad TF103C Headphone Jack: шаг 2, изображение 1 из 1
    • Slide the tool along all four edges of the laptop and continue to pull the tool upwards to fully remove the bottom case from the laptop.
  3. How to Replace Asus Transformer Pad TF103C Headphone Jack: шаг 3, изображение 1 из 1
    • Remove the back cover once it is detached then set it aside.
    • Rotate your laptop to match the orientation shown in the picture to make the guide easier to follow.
  4. How to Replace Asus Transformer Pad TF103C Headphone Jack: шаг 4, изображение 1 из 1
    • Remove the tape and unplug the wire that attaches to both speakers from the soundboard.
  5. How to Replace Asus Transformer Pad TF103C Headphone Jack: шаг 5, изображение 1 из 1
    • Use the +J000 screwdriver to unscrew and remove the M2 screw and plastic bracket.
  6. How to Replace Asus Transformer Pad TF103C Headphone Jack: шаг 6, изображение 1 из 1
    • Remove the black tape from the ribbon cable and separate the cable from the soundboard.
  7. How to Replace Asus Transformer Pad TF103C Headphone Jack: шаг 7, изображение 1 из 1
    • Use the +J000 to remove the three mounting screws from the soundboard.
    • Keep the screws together and organized. (Label, if necessary).
  8. How to Replace Asus Transformer Pad TF103C Headphone Jack: шаг 8, изображение 1 из 2 How to Replace Asus Transformer Pad TF103C Headphone Jack: шаг 8, изображение 2 из 2
    • Remove the soundboard which has the headphone jack attached to it and replace with the new soundboard.
    • Once done reassemble your device, follow these instructions in reverse order.
Заключение
Tyler Ellis
Участник с: 10/28/15
668 Репутация
Автор 4 руководств
Команду
UMass Dartmouth, Team 3-6, Shastany Fall 2015 Участник UMass Dartmouth, Team 3-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G6
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 697
