Введение
This guide outlines the basic steps to replace rectangular bag lining with a newly sewn lining, whether because the original lining was damaged or because you want a different fabric for the lining. It requires basic sewing skills to complete but will allow you to continue using a bag to its fullest with the lining like new again.
Выберете то, что вам нужно
Assess the old bag lining you will be replacing.
Consider color, material, and amount of fabric needed for the new lining.
At the seams, use your hands or sewing to carefully rip or cut out old bag lining.
Lay out old bag lining on fabric and measure out the size of the new bag lining, adding an extra 2 cm on each side.
Fold new fabric in half to create one closed end for the bag lining.
Cut out bag lining based on measurements from previous step.
Stitch the two sides of fabric adjacent to the folded side to create a rectangle with one opening.
Use stitches small and tight enough to ensure new lining remains intact.
Finish stitching 2 cm from the end of the open side.
Fold over extra 2 cm from the opening of the new bag lining outward to hide the raw edge of the fabric.
With a needle suitable for sewing through your bag material, attach the bag lining with a straight running stitch around the mouth of the bag.
