Введение
Has your battery died in your Ford keyless entry remote? If this happens your remote might lose connection from your car.Learn how to replace the battery and re-program it to your vehicle.
Выберете то, что вам нужно
Locate the space to put the screwdriver.
Put the screwdriver in this space and pry open the remote.
Take the half with the buttons and use your fingernails to take out the button pad.
Put the screwdriver in between the battery and the remote cover.
Push the screwdriver down which will make the battery pop out of the remote cover.
Get your new battery and locate the positive side.
Put the positive side facing down towards the cover.
Click it into its position.
Take the other half of the remote and put the case back together.
Get in your vehicle and make sure all doors are closed.
Put the key in the ignition.
Turn the car on.
Turn the car off.
Repeat this eight times.
Stop on the eighth time with the key turning the car on.
You will then hear the car lock then unlock, telling you that it is time to pair the remote with the vehicle.
Then press any button on the remote to pair with the car.
The car should then lock and unlock again to verify that your vehicle and your remote have paired.
Turn off the car and take it out of the ignition.
Click all four buttons to check and see if the remote is paired.
Once you can lock, unlock, open the trunk, and set off the car alarm. Your keyless entry remote has been paired.
Еще один человек закончил это руководство.
