Введение
This is a simple process that requires little skill and only one tool, but is valuable as hinges may become loose or broken with use. Concealed hinges are completely hidden from view when the cabinet door is closed. These kinds of hinges are common in many households and other establishments, and we feel this guide will be helpful to those in need of repair.
Выберете то, что вам нужно
Remove the screws that are attached to the cabinet door.
Remove the cabinet door from the hinge.
Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
Insert the new hinge into the cabinet door's pre-cut hole.
Attach the hinge with the provided screws.
Lift or lower the cabinet door to align the hinges with its original location.
Tighten all the screws.
Loosen the adjustment screws, but do not remove them.
Slide the cabinet door to your desired position.
Tighten the screws.
Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
4 участников успешно повторили данное руководство.
