How to Replace Hot and Cold Water Pipes for a Washer
Выберете то, что вам нужно
  1. How to Replace Hot and Cold Water Pipes for a Washer, How to Replace Hot and Cold Water Pipes for a Washer: шаг 1, изображение 1 из 1
    • Before starting this guide, shut off your water to the washer and dryer. In this guide, valves are used. Some newer setups may use levers.
    • Mark the hot and cold water pipelines with a marker for proper visuals.
    • Hot water
    • Cold water
  2. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: шаг 2, изображение 1 из 3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: шаг 2, изображение 2 из 3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: шаг 2, изображение 3 из 3
    • Using an adjustable wrench, disconnect the pipes carefully from the water supply side and the washer side.
    • After the pipes are disconnected, re-check the leakage and rust in the washer installation.
  3. How to Replace Hot and Cold Water Pipes for a Washer: шаг 3, изображение 1 из 1
    • Rotate the adjustable wrench in a counter-clockwise direction to loosen the pipe connection.
    • Make sure to remove the old white Teflon tape. Use a bucket and a piece of cloth for water damps from the connection.
  4. How to Replace Hot and Cold Water Pipes for a Washer, Prepare the new pipes: шаг 4, изображение 1 из 1
    • Set up the new pipes to be installed.
    • Check for blockage or any cracks in the valve.
  5. How to Replace Hot and Cold Water Pipes for a Washer, Wrap new Teflon tape: шаг 5, изображение 1 из 1
    • Wrap the new piece of Teflon tape around the shut-off valve connection.
  6. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: шаг 6, изображение 1 из 3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: шаг 6, изображение 2 из 3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: шаг 6, изображение 3 из 3
    • Install and connect the new pipes using an adjustable wrench.
  7. How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: шаг 7, изображение 1 из 2 How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: шаг 7, изображение 2 из 2
    • Rotate the pipes in a clockwise direction to tighten up.
    • Turn on the water supply. Perform a quick wash and check the connection.
Заключение
  • This guide contains easy steps of instructions to be followed if your pipes of the washer are needed to be changed.
Еще один человек закончил это руководство.
Jenish
Участник с: 01/22/21
169 Репутация
1 руководство автора
Команда
York University, Team S1-G21, Melo-Thaiss Winter 2021 Участник York University, Team S1-G21, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G21
1 член
Автор 1 руководств
Один комментарий
Those are hoses. Pipes are in the wall
NitWit - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 38
За последние 30 дней: 158
За всё время: 7,282
