How to Replace Keys on a Keyboard
Выберете то, что вам нужно
  1. How to Replace Keys on a Keyboard, Individual Keys: шаг 1, изображение 1 из 2 How to Replace Keys on a Keyboard, Individual Keys: шаг 1, изображение 2 из 2
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
  2. How to Replace Keys on a Keyboard: шаг 2, изображение 1 из 2 How to Replace Keys on a Keyboard: шаг 2, изображение 2 из 2
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
  3. How to Replace Keys on a Keyboard: шаг 3, изображение 1 из 1
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
  4. How to Replace Keys on a Keyboard: шаг 4, изображение 1 из 1
    • Clean your keys with compressed air by blowing around the removed key.
  5. How to Replace Keys on a Keyboard: шаг 5, изображение 1 из 2 How to Replace Keys on a Keyboard: шаг 5, изображение 2 из 2
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
Заключение
Congratulations! You now have a keyboard with fully functional keys!
6 участников успешно повторили данное руководство.
Cooper
Участник с: 02/24/15
457 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 24-6, Green Winter 2015 Участник Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 членов
Автор 15 руководств
2 Комментариев
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Ответить
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 52
За последние 30 дней: 262
За всё время: 16,514
