Введение
The Hohner 280C Chromonica 64 Chromatic Harmonica loses its plastic reeds over time as its binding glue degrades. This results in the harmonica not making sound where the reeds are missing. This guide will go through the steps needed to take off the face plates of the harmonica, replace the fallen reeds using glue, and reassemble the instrument.
Выберете то, что вам нужно
Using a flat-head screwdriver, remove the four 2.4 mm round head screws on left and right of the harmonica plates.
Move the harmonica plates to the side until needed for reassembly.
Place a very small amount of glue on the end of a toothpick.
Using the toothpick, spread the glue gently on the top of the reed without the split end, with the longer piece facing up.
Place the glued reed on the harmonica’s reed plate where the reed is missing.
Gently press down on the reed to adhere the glue.
Using the toothpick, spread the glue gently on the top of the bump reed without the bump, with the bump laying down.
To reassemble the side plates, align the top plate (the one with numbers) with the harmonica comb, with its open end facing down and the harmonica button on the right next to the 12.
Keep the hollow round head screw in place by pressing down on the screw with your finger, resting the harmonica on a table, etc.
Using the screwdriver, screw one of the round head screws into the opposite hollow round head screw. Leave enough slack that the plate does not rise.
Using the flathead screwdriver, tighten the round head screws into the harmonica.
Еще один человек закончил это руководство.
