Введение
If your chair seat is broken, stained, or generally worn-out, this guide will help you replace the seat's fabric and/or foam, keeping your chair out of the landfill.
A chair seat usually consists of foam covered with fabric, attached to a panel for a sturdy base. With normal use, the fabric may tear, and/or the foam may flatten or be exposed, making your chair a bit ugly or uncomfortable. After completing this guide, your chair will look and feel brand-new!
Выберете то, что вам нужно
Once the seat is separate from its base, flip it upside-down and remove the fabric staples with pliers.
Remove the fabric.
Place the foam or chair seat on top of your desired fabric.
Use a pair of scissors to cut the fabric, tracing around the foam or seat. Cut the fabric approximately 1.5 inches wider on the sides to allow it to wrap around the edges.
Center the foam on the seat board, place the fabric on top of the foam, then flip the board over.
Fold the fabric inward, toward the board.
Staple the fabric to the seat, around the entire perimeter.
After everything is stapled, cut excess fabric (if necessary) using a pair of scissors.
You're all set! Enjoy your brand-new looking chair!
3 участников успешно повторили данное руководство.
