How to Replace Your Cabin Filter
  1. How to Replace Your Cabin Filter, How to Replace Your Cabin Filter: шаг 1, изображение 1 из 2 How to Replace Your Cabin Filter, How to Replace Your Cabin Filter: шаг 1, изображение 2 из 2
    • Open your glovebox, and look for the tamper. Put a little outward pressure on it; it should just pop off.
  2. How to Replace Your Cabin Filter: шаг 2, изображение 1 из 2 How to Replace Your Cabin Filter: шаг 2, изображение 2 из 2
    • Squeeze the sides of the glove box and lower.
  3. How to Replace Your Cabin Filter: шаг 3, изображение 1 из 1
    • Remove the glove box from its hinges and set aside.
  4. How to Replace Your Cabin Filter: шаг 4, изображение 1 из 2 How to Replace Your Cabin Filter: шаг 4, изображение 2 из 2
    • Pull gently to remove the cabin filter. Some cars may have a cover that must be removed before the cabin filter can be accessed. Be sure to note how the cabin filter was installed so you can install the new one in the same manner.
    • Install your new cabin filter.
Заключение
To reassemble, carefully place the glove box back on its hinges, squeeze the sides, and reattach the damper. That's it. You've changed your cabin filter.
4 человек успешно провели ремонт по этому руководству.
Chaya Milchtein
Участник с: 07/06/23
1 057 Репутация
Автор 5 руководств
Один комментарий
My non factory air filter makes a constant whistling sound when installed and the heater on. Toyota decided to “fix” it by just removing it. No more whistling but no more filter either. They said I could buy a new factory filter and they would install it but I don't have the $80 it costs. Any thoughts or suggestions? Also does your book have pics? I really liked the pics above for the air filter replacement info. Thanks.
meanqueen80 - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 14
За последние 30 дней: 34
За всё время: 786
