Введение
Is your car having trouble starting? Is there corrosion build-up on your terminals, preventing a proper connection? This handy guide will help you remove the troublesome terminal and replace it with a brand new one.
Warning: It is dangerous to work on a vehicle battery. Exercise extreme caution when following this guide.
Инструменты
Запчасти
  1. How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: step 1, image 1 of 2 How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: step 1, image 2 of 2
    • Remember to remove your car key from the ignition and shut off the car before performing this guide.
    • Locate the terminals on the top of the car battery. Next to each terminal is a positive(+) or negative(-) sign, indicating the charge.
    • The positive terminal looks to be in working order, but the negative end has a lot of corrosion buildup. This terminal needs to be replaced.
  2. How to Replace a Corroded Car Battery Terminal: step 2, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 2, image 2 of 2
    • Find the nut located on the side of the terminal.
    • Using an adjustable wrench, rotate the nut counterclockwise to loosen it.
    • Use an appropriately-sized wrench or socket, not channel locks as shown in the photo.
    • You do not need to loosen the nut all the way off the bolt, but just enough to loosen the terminal's grip on the node.
  3. How to Replace a Corroded Car Battery Terminal: step 3, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 3, image 2 of 2
    • Always remember to remove the negative terminal first before the positive terminal. This will prevent shorting to the ground and possibly causing shock or a fire.
    • Carefully use a rag to lift up the terminal off of the battery node.
    • Be cautious when handling battery corrosion, as it can irritate the skin and is harmful if it comes in contact with your eyes.
    • Place the terminal on a rag or towel and make sure it doesn't come in contact with the battery node.
    Quite an overstatement to say ”remove the possibility” as the possibility still remains, it’s just reduced
    Erno Pentzin - Ответить
  4. How to Replace a Corroded Car Battery Terminal: step 4, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 4, image 2 of 2
    • On the positive terminal, locate the nut along the side.
    • Using the wrench, rotate the nut counterclockwise.
    • You do not need to fully loosen the nut off the bolt, but just enough for the terminal to be easily removed from the node.
  5. How to Replace a Corroded Car Battery Terminal: step 5, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 5, image 2 of 2
    • Using a rag, carefully remove the positive terminal from the battery node.
    • Place the terminal on a rag or towel, and make sure it does not come into contact with the battery node.
  6. How to Replace a Corroded Car Battery Terminal: step 6, image 1 of 3 How to Replace a Corroded Car Battery Terminal: step 6, image 2 of 3 How to Replace a Corroded Car Battery Terminal: step 6, image 3 of 3
    • On the negative terminal, locate the nut on the side facing upwards.
    • Using the wrench, rotate the nut counterclockwise and remove it from the bolt.
  7. How to Replace a Corroded Car Battery Terminal: step 7, image 1 of 3 How to Replace a Corroded Car Battery Terminal: step 7, image 2 of 3 How to Replace a Corroded Car Battery Terminal: step 7, image 3 of 3
    • Take the wire plate on top and remove it carefully from the bolt.
    • At this point, it is fine to handle the metal plate with your hands since the terminals are disconnected from the battery and there is nothing completing the circuit.
    • Remove the bottom wire plate from the bolt, placing it carefully to the side.
  8. How to Replace a Corroded Car Battery Terminal: step 8, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 8, image 2 of 2
    • Set aside the old battery terminal, and replace it with the new one.
    • Replace the wire plates in the order they were taken off.
    • Although it is not necessary that the plates be placed in the same order again, it is generally a good idea to go with the order that it came in.
  9. How to Replace a Corroded Car Battery Terminal: step 9, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 9, image 2 of 2
    • Place the flat washer and the screw-on head that came with the battery terminal onto the vertical bolt.
    • Tighten the head clockwise and make sure the wire plates are secured.
    • Not all battery terminal packs come with a washer and screw-on head. If your pack comes with a nut, use the wrench and tighten the bolt clockwise.
  10. How to Replace a Corroded Car Battery Terminal: step 10, image 1 of 1
    • Using a rag, place the positive terminal back onto the positive node.
  11. How to Replace a Corroded Car Battery Terminal: step 11, image 1 of 1
    • Place the negative terminal back onto the negative node.
  12. How to Replace a Corroded Car Battery Terminal: step 12, image 1 of 3 How to Replace a Corroded Car Battery Terminal: step 12, image 2 of 3 How to Replace a Corroded Car Battery Terminal: step 12, image 3 of 3
    • On the negative terminal, use the wrench to rotate the side nut clockwise to tighten it.
    • Next, perform the same action on the side nut of the positive terminal.
    • To ensure a secure connection, be sure the nut is snug and that the terminal can't come off easily.
Финишная черта
15 участников успешно повторили данное руководство.
David Wright
Участник с: 23.02.2015
607 Репутация
1 руководство автора
Команда
Cal Poly, Team 12-4, Green Winter 2015 Участник Cal Poly, Team 12-4, Green Winter 2015
CPSU-GREEN-W15S12G4
5 членов
Автор 7 руководств
Комментариев: 6
Nice post. Shop car battery at batterybhai and their expert technical team come to install the battery with all battery replacement tools kit.
mayank tanwar - Ответить
I change negative terminal to new one still have corrosion why?
אנדריי מזילו - Ответить
They are corrotion after doinging this within a4 to 5 month time the red cable is worst
Carol - Ответить
Use Petroleum-Jelly (preferably) OR if not there then
use Vaseline onto both the Terminals( +, -ive) to prevent rusting of your both terminals of Battery PLEASE .
SANJAY KHANDELWAL -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 37
За последние 7 дней: 299
За последние 30 дней: 1,139
За всё время: 104,624
