Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
The first step is to shift your chain onto the biggest gear on your crankset.
Then pull off the shift cable’s end cap and loosen the cable pinch 4.5mm bolt with a 5mm hex wrench. The cable will come loose from a slot underneath the derailleur.
Remove the chain from the derailleur with a Phillips 6mm screwdriver.
Before removing the clamp post, mark where it is positioned with a felt tip or Expo marker. This ensures the new part will be placed in the same position.
Unscrew the 5mm hex bolt that tightens the clamp onto the seat post.
Remove the clamp from the seat post.
This will remove the old derailleur.
Before installing the new derailleur, apply some WD-40 to the mounting bolt.
Attach the new derailleur to the chain.
Place the clamp around the frame and tighten the mounting bolt just enough to keep it in place. At this point you still need to be able to move it by hand.
Check to make sure the cage of the derailleur will clear the large chain-ring when the the hinge extends.
Take up the slack on the shifter cable with pliers and tighten down the bolt on the retaining clamp.
Thread the shift cable back into the derailleur, pull it tight and tighten the anchor bolt so the cable flattens. Then find a bare stretch of cable and give it a good pull to make sure the cable is seated and has no slack. Then loosen the cable, pull it tight again and re-tighten it.
Now reassemble the chain and remove the stiffness.
If your chain is still on the bike, undo the tail screw on the derailleur cage and flex the cage to pull the chain through. Then re-install and tighten the tail screw again.
If you have removed the chain, re-route the chain through the derailleur cage and reconnect it.
Now turn your bike upside down and change the gears.
Run through the entire range of rear sprockets to make sure the chain does not rub on either side of the front derailleur cage.
Turn the bike to standing position. Now adjust the derailleur’s height and angle. Use half turns while adjusting.
For height adjustment, the bottom edge of the outside derailleur cage should sit approximately 2mm above the top of the teeth on the largest chain-ring.
For the angle adjustment, rotate the derailleur until the cage is parallel with your chain-rings.
Adjust the derailleur limiting screws and cable tightness as needed.
2 участников успешно повторили данное руководство.
3 Комментариев
Very helpful
What model is this with open chain-case or open loop i don want to removed de chain at all.
