How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid
  1. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid, Receiver Wire: шаг 1, изображение 1 из 1
    • This is the Widex Evoke 440 Hearing Aid that we will be replacing the receiver wire on. Colors may vary.
    Спросите у FixBot
    Добавить комментарий
  2. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 2, изображение 1 из 1
    • Look for the exact part number you need, which is on the end of your Receiver.
    • The first letter corresponds to the strength of the receiver. It will be S for small, M for medium, or P for power.
    • The number corresponds to the length of the wire.
    • The next letter corresponds to which side the receiver is for, so it will be either L or R for left or right.
    Спросите у FixBot
  3. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 3, изображение 1 из 2 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 3, изображение 2 из 2
    • Remove the battery from your hearing aid.
    Спросите у FixBot
  4. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 4, изображение 1 из 3 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 4, изображение 2 из 3 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 4, изображение 3 из 3
    • Put your index finger under the curve in the wire near the base of the receiver.
    • Put your thumb over the receiver wire and grasp it tightly.
    • Pull the wire straight up out of the hearing aid.
    Спросите у FixBot
  5. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 5, изображение 1 из 1
    • Your new hearing aid receiver wire will look like this out of the box.
    Спросите у FixBot
  6. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 6, изображение 1 из 2 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 6, изображение 2 из 2
    • Slide the small plug at the end of the receiver into the hearing aid.
    • Push it all the way into the hearing aid by pushing down on the edge of the plug with your fingernail.
    Спросите у FixBot
  7. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 7, изображение 1 из 2 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 7, изображение 2 из 2
    • Put your silicone dome back on the receiver by lining it up with the receiver wire and pressing gently.
    Спросите у FixBot
  8. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid: шаг 8, изображение 1 из 1
    • Put your battery back in.
    Спросите у FixBot
Финишная прямая
4 человек успешно провели ремонт по этому руководству.
Tish Alexander
Участник с: 09/18/23
265 Репутация
1 руководство автора
3 Комментарии к руководству
Thank you so much for this page. It's the only place on the internet I found that gives the exact instructions for replacing the receiver link. Also the only place that explains exactly what the codes mean that are stamped on the receiver so that I can order the right part!
James McClure - Ответить Поделиться
I'm so glad it was helpful; thank you for letting me know!
Tish Alexander - Ответить Поделиться
Sadly, no wires found on eBay to replace the one for the Widex Evoque 440 my dog chewed up.
Wondering if any of the later model receivers+wires are both compatible and inconspicuous ?
Ueber Setzer - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 55
За последние 30 дней: 255
За всё время: 5,002
