Введение
This guide serves to breakdown the steps to replacing the filter of a PARTU BS-03 HEPA Air Purifier. This guide is necessary because a clean filter is essential to keep the air purifier working efficiently, properly, and safely. After several months, the filter will likely accumulate a lot of dust and other particles that can clog up the filter. As the filter becomes more clogged, it has to consume more energy to perform the same amount of work and will eventually filter and purify less air. By knowing how to properly replace the filter, users can rest assured that they are getting optimal use of their PARTU BS-03 HEPA Air Purifier.
Note: this guide only applies to the replacement of the filter of a PARTU BS-03 HEPA Air Purifier and not all air purifiers.
Выберете то, что вам нужно
On the bottom of the machine, turn the filter cover counter-clockwise.
Remove the filter cover.
Using the can of compressed air, spray any loose dust out of the empty filter compartment.
To reassemble the air purifier machine, follow these instructions in reverse order.
4 Комментариев
Does the gadget tells it’s user it’s time to replace it’s air filter? I mean it looks small though to clean and filter the air around it’s surroundings.
What do 16 beeps mean? Is there a downloadable manual in English to tell me this stuff?
Well is there a manual?
Did anyone find a manual for the Partu BS-03 air purifier? I have changed the filter, and reset the filter button. I still hear 3 rapid beeps every 5-10 minutes. Anyone have any insight?
