Введение
Oh no, the arm of your glasses broke!
If you wear standard-hinge eyeglasses (chances are you probably do), this guide can help. Using only a screwdriver and a replacement arm that can be purchased online or in optical stores, you can get back to seeing in no time!
Выберете то, что вам нужно
Remove the screw holding the broken arm by turning it counterclockwise.
Thoroughly clean the screw and the connecting hinge using the cleaning cloth to remove any dirt or buildup.
Align the joints of the new arm with the joint connected to the frame.
The frame joint should be in between the two joints of the arm.
Insert the screw in the hinge and lightly tighten by turning the screw clockwise.
Make sure all parts are aligned and that the new arm is not angled.
Еще один человек закончил это руководство.
