Введение
Follow this guide to replace the battery adhesive on your Motorola phone.
Выберете то, что вам нужно
Use tweezers to remove all of the old adhesive from the battery's recess.
Before removing any liners, use the guide lines on the new adhesive to find the proper orientation in the battery recess.
Use the pull tab on the blue liner to separate the adhesive from the white liner.
With the adhesive in its proper orientation, lay it sticky side down in the battery recess.
Use a spudger or your fingers to firmly press down on the blue liner to secure the new adhesive to the frame.
Before laying the battery in its recess, temporarily reconnect the battery's press connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
Lay the battery in its recess.
Firmly press down on the perimeter and center of the battery to adhere it to the frame.
Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
The battery is now ready for use. Return to your phone's repair guide and continue reassembly.
