Введение
The cabin air filter should be replaced once a year or every 10,000 miles, whichever comes first. You may want to replace it after pollen season, or more frequently, depending on your location. You won't want to put off this treatment once you realize how simple it is. Some dealers charge up to $50 for this service, which takes about 10 minutes for a skilled technician. This guide will save you some bucks and show you how to replace the cabin air filer on your 2007-2015 Mitsubishi Lancer all on your own!
Выберете то, что вам нужно
Open the glove box and empty all of its contents.
Gently push the glove box damper arm on the right side of the glovebox to the right, you can release it. The latch will be released by a pin, and the arm will be lifted out of the aperture.
Push the two locking tabs on the front left and right in towards the center with your fingers and pull off the cover.
With the cover removed, take out the old filter.
Take note of the direction the air should pass through the filter. The heating blower blows air from top to bottom . An indication mark should be present on the tray.
Place the new filter in the filter tray. The hard sides of the filter are placed on the tray's left and right edges.
Reinstall the filter cover in the heating blower in the same manner as it was removed.
Push both sides of the glove box inwards the same way as in Step 2 and push it back into the housing
Gently reinstall the damper arm on the right side of the glovebox by pushing it back into the aperture. The latch will lock back in, and the arm will be connected to the aperture.
Close the glove box and put your items back inside. You've completed the task!
2 участников успешно повторили данное руководство.
