How to Replace the Cork in a Trombone Water Key
Выберете то, что вам нужно
  1. How to Replace the Cork in a Trombone Water Key, Water Key Cork: шаг 1, изображение 1 из 2 How to Replace the Cork in a Trombone Water Key, Water Key Cork: шаг 1, изображение 2 из 2
    • Obtain a replacement water key cork.
    • If you’re in a rush and don’t have a replacement cork, you can make a temporary one out of a wine bottle cork.
  2. How to Replace the Cork in a Trombone Water Key: шаг 2, изображение 1 из 3 How to Replace the Cork in a Trombone Water Key: шаг 2, изображение 2 из 3 How to Replace the Cork in a Trombone Water Key: шаг 2, изображение 3 из 3
    • Remove the old cork.
    • Insert a sharp tool, such as one tine of a pair of tweezers or needle-nose forceps, between the cork and the metal edge.
    • Pry up the cork using the metal edge for leverage.
    • Repeat this at several points around the cork until the cork comes free.
  3. How to Replace the Cork in a Trombone Water Key: шаг 3, изображение 1 из 1
    • If you have a replacement cork, skip to Step 10.
    • If you’re using a wine bottle cork to make a replacement cork, place the cork on its side and measure 3 mm from the cork edge. Mark this point.
  4. How to Replace the Cork in a Trombone Water Key: шаг 4, изображение 1 из 2 How to Replace the Cork in a Trombone Water Key: шаг 4, изображение 2 из 2
    • Using a serrated knife (such as a steak knife), cut the cork horizontally along your mark.
    • Cutting corks can be tricky. Make sure to keep fingers out of your knife's way.
  5. How to Replace the Cork in a Trombone Water Key: шаг 5, изображение 1 из 1
    • Using a ruler, measure the diameter of the water key slot you removed the cork from in Step 2.
    • Measure from inside edge to inside edge.
  6. How to Replace the Cork in a Trombone Water Key: шаг 6, изображение 1 из 1
    • Place the 3mm slice you cut from the wine cork flat on a surface.
    • Mark a point in the center.
  7. How to Replace the Cork in a Trombone Water Key: шаг 7, изображение 1 из 2 How to Replace the Cork in a Trombone Water Key: шаг 7, изображение 2 из 2
    • Using a ruler, measure half the diameter from Step 5 above and below the center mark.
  8. How to Replace the Cork in a Trombone Water Key: шаг 8, изображение 1 из 2 How to Replace the Cork in a Trombone Water Key: шаг 8, изображение 2 из 2
    • Rotate the ruler 90 degrees and repeat Step 7.
    • Your cork slice should now have four marks equidistant from the center mark.
    • Draw a circle connecting the four marks around the center.
  9. How to Replace the Cork in a Trombone Water Key: шаг 9, изображение 1 из 3 How to Replace the Cork in a Trombone Water Key: шаг 9, изображение 2 из 3 How to Replace the Cork in a Trombone Water Key: шаг 9, изображение 3 из 3
    • Using your knife, cut out this circle.
    • It helps to slice edges off at angles, one at a time.
    • This might take a few tries, so if you end up with a non-round circle cut out, repeat Steps 3-9 with the remaining wine cork.
  10. How to Replace the Cork in a Trombone Water Key: шаг 10, изображение 1 из 1
    • Dry fit the new cork in the water key slot to make sure it is the right size.
    • If your cork is too big, you'll need to cut it a little smaller.
    • If your cork is a little uneven, don't worry. Its job is to seal the water hole, which is much smaller than the cork itself.
  11. How to Replace the Cork in a Trombone Water Key: шаг 11, изображение 1 из 2 How to Replace the Cork in a Trombone Water Key: шаг 11, изображение 2 из 2
    • With a hot glue gun, put a drop of glue in the water key slot and place the new cork on top.
    • Press firmly on the cork for a few seconds.
Заключение
If your water key still leaks after replacing the cork, it may need to be bent back into place or may need a new spring. See an instrument repair professional or another online guide for help with this.
6 участников успешно повторили данное руководство.
Esther Unti
Участник с: 02/24/15
266 Репутация
1 руководство автора
Команда
Cal Poly, Team 23-3, Green Winter 2015 Участник Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
6 членов
Автор 13 руководств
Один комментарий
Let me suggest that there is an easier way to a permanent solution for leaky corks - remove the water automatically by installing a JoyKey. No more leaking corks, no moving parts, no sptings or having to manually deal with water.
For more information:
www.thejoykey.com and http://thejoykey.com/wp-content/uploads/...
andrew - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 40
За всё время: 13,264
