Введение
Has your stereo blown out one or both of your tweeters? Use this guide to help you replace them.
Выберете то, что вам нужно
Take your flat head screwdriver and gently pry off the plastic grille covering your tweeter.
There are 4 clips holding the grille down, 1 in each corner. Be careful not to break them.
Take your offset screwdriver and unscrew the screws holding down the tweeter bracket.
Some models and years have 2 screws, others have 4. Remove them all.
Gently lift the tweeter bracket with the tweeter inside and locate the connector.
If your tweeter only has 2 screws, attach a zip tie through the other holes and over the tweeter to help secure it in place.
Cut off the excess tie.
Take any excess cable and fold it neatly so that it will fit down the hole below the tweeter.
Place the new tweeter and bracket assembly back into the dashboard.
Make sure the orientation is how you would like it, and that the holes of the bracket line up with the holes in the dashboard.
Place the screws from the original tweeter back in their holes and tighten them with the offset screw driver.
You have succesfully replaced your tweeter. Follow the same steps to do the other side and test your stereo to make sure they are installed properly.
4 участников успешно повторили данное руководство.
