Введение
The purpose of this technical description is to explore the Utilitech SFC1-500B 20” High Velocity Floor Fan at the system-level, then discuss the important parts directly related to using the device. This description will give the user a basic idea of fan’s design and operation so as to become more proficient in its use.
Выберете то, что вам нужно
Remove the screws holding the plastic wire cover with a Phillips #2 screwdriver and flexible extension.
If the above attachment is unavailable, use a crescent wrench or pliers to grip the screwdriver for additional torque.
Remove the nuts securing the motor to the back cover of the fan, using a Phillips #2 screwdriver and an 8mm socket driver.
Remove the power cord from the back cover by sliding the wire off of the two metal rails holding them together.
2 участников успешно повторили данное руководство.
6 Комментариев
do you have the wiring schematics for this fan my wire broke from the copper coil thank you
My Ulitiech fan suddenly stopped working. What can I do to get it to work again. Or is it my new door stop?
My cord on my utilitech floor fan was severed by my table saw and I’ve spliced the cord and it still won’t work. Could there be a reset button or something I’m missing?
You title this on how to remove the fan blades then don't actually show how to remove the fan blades but get the whole motor with the fan blades attached.
