Введение
If the line on your spinning reel keeps getting tangled up, is often breaking unexpectedly, or you want to avoid losing your next big catch, it may be time to replace your old line with some fresh filament.
Over time, even with proper care, fishing line degrades from exposure to UV rays, stress, and abrasion. This guide will walk you through all the necessary steps to properly replace the old line on your spinning reel and prevent frustrating setbacks while fishing.
Выберете то, что вам нужно
Find the recommended line weights on the side of the reel and purchase the specified line.
Flip up the metal bail on the spinning reel.
Remove the old line by pulling it off the top of the reel.
Feed the end of the new line through the first eyelet of the fishing rod.
Tie a single overhand knot towards the end of the line.
With the bail still up, wrap the line around the reel and tie a double overhand knot.
Tighten the line up to the first knot made in the previous step.
Flip the bail down and slowly reel the line, keeping light tension using your finger.
Continue reeling until there is roughly an 1/8th of an inch of radial space left on the reel.
Use utility scissors to cut the line free of the spool.
Clip the free end into the line holder on the side of the reel.
