How to Replace the Headlight in a 2010-2014 Volkswagen Jetta
Выберете то, что вам нужно
  1. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: шаг 1, изображение 1 из 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: шаг 1, изображение 2 из 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: шаг 1, изображение 3 из 3
    • Turn the ignition fully off and open the hood of your vehicle.
    • The lever to open it is on the left hand side of the pedals. It’ll make a noticeable clunk sound when pulled the first time which releases the first of the two step hood opening procedure.
    • Make your way to the front of the car and push up on the lever underneath the hood to fully open the hood.
    • Use the hood prop rod to hold the hood open for the duration of the repair.
  2. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: шаг 2, изображение 1 из 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: шаг 2, изображение 2 из 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: шаг 2, изображение 3 из 3
    • Locate the plastic dust cover behind the burnt headlight and gently remove it. If the cover is stuck, you can use a screwdriver to pop it out.
  3. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: шаг 3, изображение 1 из 2 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: шаг 3, изображение 2 из 2
    • Once the cover is off, twist the light harness from the fixture in a counter clockwise rotation.
    • Pull the bulb to separate it from the connector.
    • Insert the new bulb in the correct orientation as the previous, and tighten it back into the headlight by rotating it clockwise.
  4. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: шаг 4, изображение 1 из 1
    • Reapply the dust cover and close the hood of the vehicle.
  5. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: шаг 5, изображение 1 из 1
    • Turn the ignition on and switch on the lights to test the new working headlight.
Заключение
To replace the other headlight. follow the same instructions.
Seyed-Mohammad Hosseiny
Участник с: 09/22/20
159 Репутация
1 руководство автора
Команда
York University, Team S1-G34, Woodhouse Fall 2020 Участник York University, Team S1-G34, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G34
1 член
Автор 1 руководств
6 Комментариев
Am I missing something? Or is there a trick to those tabs to release the bulb?
Dez Petrovic - Ответить
They are a pull to release mechanism. no need to undo tabs.
Seyed-Mohammad Hosseiny -
Don’t forget to wear gloves when handling halogen light bulbs!
Where’s the driving lights?
Ted Stoffers - Ответить
I installed the new bulb but it still doesn’t work. My neighbor, a retired mechanic came to help and undid both and put back and now, both headlights don’t work. Any other advice?
Emilia Lievano - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 21
За последние 7 дней: 94
За последние 30 дней: 465
За всё время: 21,180
