Введение
If you have an old basketball net that needs replacing, check out this guide!
Выберете то, что вам нужно
Loop the first net loop through the basketball rim.
Push the net through each loop on the basketball rim.
Pull the net loop down and spread the rope across the rim coil as shown
Pull the net tightly to the rim.
Using the same technique from step 2, loop the remaining net loops around the rim.
Now that you've replaced your net, you're ready play some basketball.
3 участников успешно повторили данное руководство.
3 Комментариев
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
i don't have these things were I can like put the net in
do you mean they dont have the little hooks that the net latches on to onto the hoop?
tayola -
