Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If you have an old basketball net that needs replacing, check out this guide!
Инструменты
Инструменты не указаны.
Запчасти
  1. Set up a ladder below the basketball rim.
    • Set up a ladder below the basketball rim.
    • Make sure the ladder is steady and placed on a level surface.
  2. Loop the first net loop through the basketball rim. Push the net through each loop on the basketball rim. Pull the net loop down and spread the rope across the rim coil as shown
    • Loop the first net loop through the basketball rim.
    • Push the net through each loop on the basketball rim.
    • Pull the net loop down and spread the rope across the rim coil as shown
    • Pull the net tightly to the rim.
  3. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Using the same technique from step 2, loop the remaining net loops around the rim.
    • Using the same technique from step 2, loop the remaining net loops around the rim.
  5. Test the net and remove any wrinkles by pulling down on the bottom of the net.
    • Test the net and remove any wrinkles by pulling down on the bottom of the net.
  6. Step down from the ladder and play ball.
    • Step down from the ladder and play ball.
Заключение
Now that you've replaced your net, you're ready play some basketball.
2 участников успешно повторили данное руководство.
Kevin A Walker
Участник с: 24.02.2015
143 Репутация
1 руководство автора
Команда
Cal Poly, Team 23-3, Green Winter 2015 Участник Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
6 членов
Автор 13 руководств
Один комментарий
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
akiborja1017 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 54
За последние 7 дней: 373
За последние 30 дней: 1,725
За всё время: 73,686
