Введение
This guide is to help you replace your old spark plug with a brand new one without having to go out and buy a brand new blower. Your spark plug is what ignites the air/fuel mixture. It’s what creates the explosion which makes your engine produce power, so if this isn’t functioning properly for you, then this is the guide for you. This guide is made specifically for a Craftsman blower, specifically the Craftsman Speed Start 27cc 2-cycle leaf blower and vac.
Выберете то, что вам нужно
Use your 5/8" socket attached to a socket wrench to unscrew the spark plug from the engine.
Insert the new spark plug into the hole and tighten it a bit with your fingers to find the threads.
Use the 5/8" socket wrench to tighten the spark plug until it is snug.
Inspect the area and make sure the spark is in level.
Replace the spark plug injector boot to cover the spark plug.
Now that you've successfully changed out your old spark plug with a new one, follow the manufacturer's instructions on the side of the blower and make sure it starts up properly.
Now that you’re done, your blower should now work. If there are any questions on how to reassemble your blower you can follow the instructions below:
You should follow these instructions in reverse. First, you’ll insert the spark plug into its correct spot, then you’ll take the injector coil cover and put it back on, and finally you’ll follow the instructions on the side of the blower to start it.
