How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter
Выберете то, что вам нужно
  1. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: шаг 1, изображение 1 из 2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: шаг 1, изображение 2 из 2
    • Make sure that the motor is off and has had time to cool after being used.
    • Push in the clips on the top of the cover, and remove the cover.
  2. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: шаг 2, изображение 1 из 1
    • Make a note of the position of the filter, and remove the cover.
  3. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: шаг 3, изображение 1 из 1
    • Lightly bend the filter so that you can see all surfaces of the filter.
  4. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: шаг 4, изображение 1 из 1
    • Use compressed air to blow out dirt or dust particles from the air filter.
    • You can bend it in several places to make sure you clean between each of the fins.
  5. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: шаг 5, изображение 1 из 1
    • Seat the filter in the same position you made a note of in Step 2.
    • If the filter is still bent from cleaning it, lightly bend it in the opposite direction so that it can lay flat in your hand.
    • Place the cover onto the air filter. This shouldn't require any force, so the filter may need to be readjusted if it does require force.
  6. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: шаг 6, изображение 1 из 2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: шаг 6, изображение 2 из 2
    • Push the clips of the cover in until they click.
    • Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
Финишная черта
Еще один человек закончил это руководство.
Pearce McKee
Участник с: 03/31/20
133 Репутация
1 руководство автора
Команда
University of Memphis, Team S5-G1, Willis Spring 2020 Участник University of Memphis, Team S5-G1, Willis Spring 2020
UM-WILLIS-S20S5G1
2 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 57
За всё время: 1,321
