How to Repot a Dying Plant
Выберете то, что вам нужно
  1. How to Repot a Dying Plant, How to Repot a Dying Plant: шаг 1, изображение 1 из 2 How to Repot a Dying Plant, How to Repot a Dying Plant: шаг 1, изображение 2 из 2
    • Remove the entire plant from its previous pot by grasping the plant at the base of the stem and gently removing the soil and dead plant material from the plant roots with your fingers.
    • Warning: Be cautious not to break any living roots while removing the soil.
  2. How to Repot a Dying Plant: шаг 2, изображение 1 из 2 How to Repot a Dying Plant: шаг 2, изображение 2 из 2
    • Place only the roots in the hydrogen peroxide/water mixture to soak.
  3. How to Repot a Dying Plant: шаг 3, изображение 1 из 1
    • Cover the bottom of the new pot with small rocks to ensure proper soil drainage.
    • Tip: Make sure the rocks are not too big as they may stop water from draining out.
  4. How to Repot a Dying Plant: шаг 4, изображение 1 из 2 How to Repot a Dying Plant: шаг 4, изображение 2 из 2
    • Fill the new pot halfway with fresh potting soil.
  5. How to Repot a Dying Plant: шаг 5, изображение 1 из 1
    • Press a small hole into the top of the soil.
    • Tip: The hole should not go deeper than the roots of the plant.
  6. How to Repot a Dying Plant: шаг 6, изображение 1 из 2 How to Repot a Dying Plant: шаг 6, изображение 2 из 2
    • Place the plant roots-first in the hole and gently push the surrounding soil over them. If necessary, fill in the sides around the plant base with soil for stability.
    • Warning: Do not press down on the soil as this can decrease the drainage capacity.
Заключение
Your plant should thrive now that it is able to extend its roots in a larger pot. Proper care and sunlight will ensure your plant lives a long and healthy life, however, these steps can be repeated in the future if necessary.
Еще один человек закончил это руководство.
Bria Bynum
Участник с: 10/26/21
136 Репутация
1 руководство автора
Команда
University of North Texas, Team 4-3, Thomas Fall 2021 Участник University of North Texas, Team 4-3, Thomas Fall 2021
UNT-THOMAS-F21S4G3
3 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 10
За последние 30 дней: 61
За всё время: 1,541
