How to Repress a Broken Makeup Compact
Выберете то, что вам нужно
  1. How to Repress a Broken Makeup Compact, How to Repress a Broken Makeup Compact: шаг 1, изображение 1 из 2 How to Repress a Broken Makeup Compact, How to Repress a Broken Makeup Compact: шаг 1, изображение 2 из 2
    • If some of the product remains unbroken, break it down using a toothpick . Completely crush the powder for a smooth fix.
  2. How to Repress a Broken Makeup Compact: шаг 2, изображение 1 из 2 How to Repress a Broken Makeup Compact: шаг 2, изображение 2 из 2
    • Add a few drops of rubbing alcohol to the broken product (the amount differs based on how much product you have left) and then thoroughly mix the alcohol into the powder with a toothpick.
  3. How to Repress a Broken Makeup Compact: шаг 3, изображение 1 из 1
    • Place plastic wrap over the product and pull taut to reduce wrinkles in the plastic wrap.
  4. How to Repress a Broken Makeup Compact: шаг 4, изображение 1 из 2 How to Repress a Broken Makeup Compact: шаг 4, изображение 2 из 2
    • Press and smooth the product out using your finger or a spoon.
    • This may take some patience depending on how smooth you would like your product to turn out.
  5. How to Repress a Broken Makeup Compact: шаг 5, изображение 1 из 1
    • Once smoothed, remove the plastic wrap and allow the compact to dry for 6-8 hours.
    • Pro tip: If you need to use your product soon, you can speed up drying time by using a hairdryer on low heat!
  6. How to Repress a Broken Makeup Compact: шаг 6, изображение 1 из 2 How to Repress a Broken Makeup Compact: шаг 6, изображение 2 из 2
    • Lastly, enjoy your product! It provides the same pigment and performance as it once did before the break.
Заключение
This method will save you money and preserve your favorite powder products without compromising its quality or pigment. I hope you found my guide useful.
Your friendly makeup lover,
Alexis
2 участников успешно повторили данное руководство.
Alexis Wilhelm
Участник с: 05/01/20
181 Репутация
1 руководство автора
Команда
UW Tacoma, Team S1-G49, Cardinal Spring 2020 Участник UW Tacoma, Team S1-G49, Cardinal Spring 2020
UWT-CARDINAL-S20S1G49
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 23
За последние 30 дней: 107
За всё время: 2,319
