Введение
If your athletic shoes have creased toeboxes due to a high amount of usage, or you simply want to get a fresh look for your kicks, use this guide to reshape the toebox of your shoes.
Although there are many guides for reshaping and uncreasing the toebox of shoes, this guide is specific for athletic shoes such as runners and trainers. It will instruct you on how to remove creases in the toebox as well as how to reshape your shoes to almost original form. A hair dryer is used in this guide, which will lower the risk of injury and damage to your shoes, compared to other guides that mostly use an iron with significantly higher temperature.
Before using this guide, make sure the material of your shoes is not vulnerable to heat (40-50 Celsius degree) such as leather, because in Step 5, you will need to use the hair dryer on the toebox.
Выберете то, что вам нужно
Stuff the middle of the toebox with cloth such as: towel, socks, et cetera to original form.
Place the shoe on the edge of a hard surface.
Manually bend the shoe gently and slowly, start from the middle to the tip of the shoe.
Turn your hair dryer to the highest temperature mode.
Heat up the toebox and the sides of the shoes in circular motion.
After completing this guide, your shoes are ready. You can reshape your shoes once or twice a month to keep them look good.
Еще один человек закончил это руководство.
Один комментарий
This guide is a game-changer for sneaker enthusiasts like me! 🙌 I've always been bummed when my favorite athletic shoes got creased, but now I have a solution that doesn't involve risking damage with an iron. Your step-by-step instructions and emphasis on shoe material safety are much appreciated.
