How to Resolder the LEDs on a Seville Classics MSC10166
Выберете то, что вам нужно
  1. How to Resolder the LEDs on a Seville Classics MSC10166, PCB (Printed Circuit Board): шаг 1, изображение 1 из 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. How to Resolder the LEDs on a Seville Classics MSC10166: шаг 2, изображение 1 из 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. How to Resolder the LEDs on a Seville Classics MSC10166: шаг 3, изображение 1 из 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. How to Resolder the LEDs on a Seville Classics MSC10166: шаг 4, изображение 1 из 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. How to Resolder the LEDs on a Seville Classics MSC10166: шаг 5, изображение 1 из 2 How to Resolder the LEDs on a Seville Classics MSC10166: шаг 5, изображение 2 из 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. How to Resolder the LEDs on a Seville Classics MSC10166, How to Resolder the LEDs on a Seville Classics MSC10166: шаг 6, изображение 1 из 1
    • Shown is the top side of the printed circuit board that contains the LEDs.
    • Inspect the PCB for any faulty connections or loose components.
  7. How to Resolder the LEDs on a Seville Classics MSC10166: шаг 7, изображение 1 из 3 How to Resolder the LEDs on a Seville Classics MSC10166: шаг 7, изображение 2 из 3 How to Resolder the LEDs on a Seville Classics MSC10166: шаг 7, изображение 3 из 3
    • Make sure the wires on the side of the board are properly connected.
    • If the wires have are not connected properly, re-solder them to the board using the soldering iron.
Заключение
Еще один человек закончил это руководство.
Queena Phung
Участник с: 09/26/12
114 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 15-46, Forte Fall 2012 Участник Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 членов
Автор 6 руководств
3 Комментариев
Good stuff except for the fact that the most common problem(fan not working) that is for me, the first and simplest repair listed is referred to a dead end in led repair section. I could be wrong, but still, where is the fuse and how does the ohm meter work for a fuse test again? Hey, your fixer guide is the one that brought it up in the first place. Just saying.....
Finner 69 - Ответить
Agreed with Finner 69, that where is the fuse and how does the ohm meter work for a fuse test again? I have Seville Ultraslimline tower fan and fan not working. Power there.
Ava - Ответить
Did you fix your fan? The fuse is on the printed circuit board with the LEDs. Set your multimeter to ohms. Touch the red lead to one side of the fuse and the black to the other. If the fuse is good, the reading should go to zero or near zero. If it's blown, it will stay at one. Mine was good, so I have to continue looking for the problem.
edtrembickiguy -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 18
За последние 30 дней: 33
За всё время: 7,854
