Введение
Before starting this project, you should wear gloves and a mask if possible for the sanding. Also this process is useful so you can make sure you can keep your wood looking good and protected so it doesn’t rot and the wood can last longer.
Выберете то, что вам нужно
Wipe down the wood with a rag or a towel to take clean the wood.
Wipe down the sanded part with the rag so when you paint on the wood you don't get the brush dirty with dust from the wood.
Paint the wood and make sure to cover all surfaces of the wood.
Let it dry and repaint the wood a couple more times to ensure all of the surfaces have been properly coated.
To do this process again just follow these steps again and this process should be done again in 6-7 months
