Введение
This is a technique guide on how to repair a synthetic wig's quality (dry, tangled, knotted). This guide is perfect for keeping your favorite wig for everyday use or special events, such as Halloween, in great condition for months to years longer than a wig with little to no care.
This process is better suited for straight, wavy, and/or loose curl synthetic wigs.
In order to keep your synthetic wig in good quality, this process must be repeated every 2-3 weeks.
Выберете то, что вам нужно
Fill your container of choice with warm to hot water (enough to cover the entire wig).
Apply the hair shampoo of your choice into the container.
Mix shampoo into the water thoroughly.
Mix shampoo into the water to clean and moisturize the wig thoroughly.
Rinse the shampoo from the synthetic wig with warm water from the bottom to the top.
Comb or brush through your synthetic wig to remove knots and tangles, from the bottom to the top.
Dump the old water from the container and fill it with fresh, warm to hot water.
Add the synthetic wig back into the fresh water in your container. Apply the hair conditioner of your choice into the container.
If using a bottle with a pump, apply 5-7 pumps of conditioner to the water.
If using a squeeze bottle, count to 5 (seconds) while pouring the conditioner into the water.
Mix conditioner into the water to moisturize the wig thoroughly.
Rinse the conditioner or Silicon Mix from the wig with warm water from the bottom to the top.
Ring out excess water from your wig.
Do one last comb or brush through to make sure there are no more tangles or knots in the wig.
Pat dry with a soft microfiber towel.
Apply the wig to the mannequin head.
Leave wig on the mannequin head to dry for one day.
For immediate use of wig, dry with hair dryer on medium to low heat.
