Введение
This guide will show how to restore a damaged corkboard that may have holes or tears in it. This fix can be used on any size board. It can be especially useful for boards that are mounted on a wall and are expensive to replace.
Выберете то, что вам нужно
Use a rag, soap, and water to scrub the damaged area to remove residual pieces of cork and glue.
Allow the area to dry.
Smooth out the wood filler using a putty knife.
Hold the putty knife at an angle and use long strokes to flatten the filler as much as possible.
Wait 1 hour for the filler to dry.
This guide will help you keep your old cork boards instead of trying to replace them. I hope you found our guide useful.
