Введение
If you have a lace frontal or lace closure wig that needs to be freshened up due to lace adhesive and excessive product in the hair, follow these simple steps.
Выберете то, что вам нужно
Place your wig on the mannequin head and gently comb out the tangles starting from the ends all the way to the root before beginning the process.
Fill a large bowl with warm to hot water.
Add dish soap to create the soapy water to clean the residue out of the lace.
Place ONLY the lace frontal portion of the unit into the soap water.
Allow it to soak for about 10-15 minutes.
Use a clean towel to gently rub the adhesive towards the edge of the lace to completely remove the adhesive.
Squeeze shampoo across the root to the ends to have an even amount of shampoo to wash the unit.
Massage shampoo thoroughly through the entire unit.
Rinse entire unit to prep for conditioning.
Squeeze about pea size of conditioner into your finger tips.
Massage the conditioner into the ends of the unit and continue up throughout the unit up to the root.
Use a wide tooth comb or shower hair brush to distribute product evenly through the unit.
Rinse conditioner out of unit thoroughly.
Use a wide tooth comb or shower hair brush to detangle the unit again.
Use a heat protectant and blow dry or place the unit on a mannequin head to air dry.
If you ever need help with refreshing an old wig or a dirty wig, refer back to this guide
