How to Restore a Torn Nike Flip-Flop
Выберете то, что вам нужно
  1. How to Restore a Torn Nike Flip-Flop, How to Restore a Torn Nike Flip-Flop: шаг 1, изображение 1 из 1
    • Remove all rough edges with 120 grit sandpaper from the torn parts of the flip-flop.
  2. How to Restore a Torn Nike Flip-Flop: шаг 2, изображение 1 из 2 How to Restore a Torn Nike Flip-Flop: шаг 2, изображение 2 из 2
    • Clean off any additional residue with soap, water, and a towel or toothbrush.
    • Allow the flip-flop to air dry before moving on.
  3. How to Restore a Torn Nike Flip-Flop: шаг 3, изображение 1 из 1
    • Gently apply the adhesive on the torn parts of the flip-flop.
    • Make sure the torn parts are completely covered. Overspill is okay.
    • Connect and hold the parts of the flip-flop to the adhesive with your hands for 5 minutes. After the 5 minutes the adhesive will be hard enough to let it sit. Let the adhesive dry for 24 hours.
    • Be sure to wear gloves and be in a ventilated environment when applying the adhesive.
  4. How to Restore a Torn Nike Flip-Flop: шаг 4, изображение 1 из 1
    • Once the adhesive is dry remove any extra adhesive that might have spilled over with the sandpaper.
  5. How to Restore a Torn Nike Flip-Flop: шаг 5, изображение 1 из 3 How to Restore a Torn Nike Flip-Flop: шаг 5, изображение 2 из 3 How to Restore a Torn Nike Flip-Flop: шаг 5, изображение 3 из 3
    • Take the needle and thread and begin to sew a cross stitch from the strap to the torn part of the flip-flop.
    • It may be easier to use an upholstery needle to get through the rubber material.
  6. How to Restore a Torn Nike Flip-Flop: шаг 6, изображение 1 из 1
    • Cover the stitched region with Plasti Dip.
    • Allow 4 hours to dry.
    • Make sure to apply the Plastic Dip in a proper environment with venalation or outside.
Заключение
The Nike Flip-Flop(s) are now restored and can be worn again.
7 участников успешно повторили данное руководство.
Adrian Yearby
Участник с: 07/12/17
265 Репутация
1 руководство автора
Команда
Texas Tech, Team S1-G2, Rauch Summer 2017 Участник Texas Tech, Team S1-G2, Rauch Summer 2017
TTU-RAUCH-SU17S1G2
2 членов
Автор 1 руководств
2 Комментариев
Hi Andrew! Thank you so much for this example. What kind of adhesive did you use, because there are so many versions. Thank you.
masood daud - Ответить
Oh darn I see it now.lol
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 21
За последние 30 дней: 71
За всё время: 15,584
