How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse
Выберете то, что вам нужно
  1. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse, How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 1, изображение 1 из 3 How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse, How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 1, изображение 2 из 3 How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse, How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 1, изображение 3 из 3
    • Remove the AAA batteries from the battery compartment under the mouse.
  2. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 2, изображение 1 из 3 How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 2, изображение 2 из 3 How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Using a plastic card, create leverage under the top plate. Start at the mouse buttons and make your way to the back of the mouse.
    • Notice how the mouse buttons are raised after you create leverage under the top plate.
  3. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 3, изображение 1 из 2 How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 3, изображение 2 из 2
    • Using a plastic spudger, make your way to the back of the mouse. There are two hidden tabs that you can push outwards, and you can feel them once your spudger is in the center of the mouse. Apply pressure outwards on the hidden tabs in order to remove the top plate.
    • Notice how the top plate is separated from the mouse once successfully removed.
  4. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 4, изображение 1 из 1
    • Remove the four 5mm screws from the back plate.
    • Remove the back plate from the mouse.
  5. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 5, изображение 1 из 1
    • Locate the magnets and separate them from each other.
    • Notice how in this example, the magnets are stuck to the battery terminals. The magnets can be stuck to any metal surface inside the mouse.
    • Each of the magnets has a marking that shows what orientation the magnets should be in.
  6. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 6, изображение 1 из 3 How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 6, изображение 2 из 3 How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 6, изображение 3 из 3
    • Place a magnet with the marked pole facing up into each of the 6 slots.
    • Use the battery cover to your advantage by placing it into the battery compartment. That way, the magnets stay in place when they are placed in their slots.
  7. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 7, изображение 1 из 1
    • Use a hot glue gun to glue the magnets in place.
    • Be careful while using the hot glue gun! It may melt the plastic of the mouse if used for too long.
    • An alternative to hot glue is to use electrical tape in order to secure the magnets.
  8. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 8, изображение 1 из 1
    • Ensure that the back plate is in the correct orientation so that the scroll-wheel can fit through the hole.
  9. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 9, изображение 1 из 1
    • Secure the back plate onto the mouse by screwing in the four 5mm screws.
  10. How to Restore the Magnetic Functionality of the Microsoft Surface Mobile Mouse: шаг 10, изображение 1 из 1
    • Place the top plate in the correct orientation so that the scroll-wheel can fit through the opening, and press down to snap the plate into place.
Финишная черта
3 участников успешно повторили данное руководство.
Raymond Ly
Участник с: 05/10/20
262 Репутация
1 руководство автора
Команда
York University, Team S1-G18, O'Regan Summer 2020 Участник York University, Team S1-G18, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G18
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 21
За последние 30 дней: 110
За всё время: 4,236
