Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Unscrew the tassel and set aside.
Using a flathead screwdriver, open the cord stop, remove from the strings, and set aside.
Close the shade and push up, sliding the shade out toward the center of the room.
Place the shade on a flat surface to work on.
Measure and cut the new nylon strings. To be safe, the length should be equal to the sum of the window width and twice the window height. There will be excess string and it will be cut off in step 14.
Use the flathead screwdriver to take the end caps off of the top rail and set aside.
Take out the screw using the phillips screwdriver and slide the top rail off.
Using the needle nose pliers, push the cord lock clips in from the side and slide the cord lock out, removing the strings and setting the cord lock aside.
Flip the shade over and pull the end caps off of the bottom rail. Set them aside.
Slide the bottom rail off and set aside.
Untie the ends of the strings between the weights on the bottom of the shade.
Pull the strings out of the shade and discard.
Thread the new string through the restringing needle.
Pull the needle and thread through the shade, making sure to leave three inches out of the bottom side of the shade.
Repeat for the other strings.
Tie a knot with the 3 inch piece and pull the string tight.
Slide the bottom rail back onto the shade.
Push the bottom end caps back onto the rail.
Turn the top rail over so that the top is on the work surface.
Thread the strings through the small gap in the top rail that the cord lock was removed from.
Restring the cord lock by first picking up the strings coming out of the cord lock gap. Thread them through the side opening of the cord lock and out of the back opening.
Thread them back through the back opening and out of the front opening. Make sure to pass the strings through the black rectangular piece inside the cord lock.
Pull the strings tight so that the strings are only in the front and side openings.
Insert the cord lock into the gap in the top rail with the opaque plastic side facing up.
Lay the strings down the middle of the shade.
Slide the top rail onto the shade, pulling the strings tight through the cord lock.
Use the phillips screwdriver to put the screw back into the top rail.
Push the end caps back into place.
Rehang the shade by pushing the shade up into the clips and sliding it towards the window.
Open the shade and cut the strings so the ends are halfway up the shade.
Place the strings inside the cord stop and close it.
Adjust the cord stop to your liking.
Slide the top half of the tassel over the ends of the strings and tie the ends together.
Screw the lower half of the tassel onto the top half.
3 участников успешно повторили данное руководство.
6 Комментариев
Are the directions different for top down/bottom up shades?
Hi - thank you so much for this post. I followed it picture by picture and managed to restring my blind which was broken. I had been quoted NZ$150 to have it fixed so though - I may as well try to DIY and see how I went. I was nervous and had to go back and forth a few times with the steps but all in all it took me about an hour to do this job and I am so happy. String cost me NZ$12.99 and there’s plenty more to do another blind! Thank you again.
Where did you buy the replacement string?
