How to Reuse Dry Nail Polish
Выберете то, что вам нужно
  1. How to Reuse Dry Nail Polish, How to Reuse Dry Nail Polish: шаг 1, изображение 1 из 1
    • Find a clean workplace where you can easily clean up spills.
    • DO NOT USE ACETONE TO THIN THE NAIL POLISH. Acetone is a solvent for removing nail polish. It can make the nail polish work but, the end result is dull or lumpy nail polish.
    • You can use a few drops of 91% isopropyl alcohol or ethyl acetate as solvents for thinning nail polish.
  2. How to Reuse Dry Nail Polish: шаг 2, изображение 1 из 2 How to Reuse Dry Nail Polish: шаг 2, изображение 2 из 2
    • Open the bottle of dry nail polish setting the brush to the side.
    • Open the bottle of nail polish thinner.
    • Squirt 2 drops of nail polish thinner into the dry nail polish.
    • Screw the top back onto the dry nail polish and roll the bottle between your hands to mix. Shaking the bottle can put air bubbles in the nail polish and ruin a manicure.
    • Be careful to not not spill any nail polish thinner.
  3. How to Reuse Dry Nail Polish: шаг 3, изображение 1 из 2 How to Reuse Dry Nail Polish: шаг 3, изображение 2 из 2
    • If the nail polish is still dry or thick repeat steps 2-3 until the nail polish is finally thinned.
    • Do not apply too much nail polish thinner, this will result in watery nail polish.
Заключение
The nail polish should reach its regular consistency after applying the nail thinner. You may then be able to apply your nail polish onto your nails.
6 участников успешно повторили данное руководство.
Iridian Vaca
Участник с: 04/09/15
289 Репутация
1 руководство автора
Команда
Cal Poly, Team 28-5, Green Spring 2015 Участник Cal Poly, Team 28-5, Green Spring 2015
CPSU-GREEN-S15S28G5
3 членов
Автор 9 руководств
Один комментарий
If the nail polish is just thick, you can run hot water over the bottle for a few minutes to thin it down some. You don't want to shake a bottle of nail polish to mix it, it can put air bubbles in the mixture, instead roll the bottle between your hands. Nice first guide, GL here.
ABCellars - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 24
За последние 30 дней: 71
За всё время: 25,570
