How to Sew a Whip Stitch
Выберете то, что вам нужно
  1. How to Sew a Whip Stitch, How to Sew a Whip Stitch: шаг 1, изображение 1 из 2 How to Sew a Whip Stitch, How to Sew a Whip Stitch: шаг 1, изображение 2 из 2
    • Align the two pieces of material you will be stitching together.
    • Thread your needle and tie a knot in the end of the thread.
    • We'll use a bright-colored thread for better contrast, but you may want to select a thread that matches the color of your fabric.
    • Drive the needle into the bottom layer of material from the back side.
  2. How to Sew a Whip Stitch: шаг 2, изображение 1 из 3 How to Sew a Whip Stitch: шаг 2, изображение 2 из 3 How to Sew a Whip Stitch: шаг 2, изображение 3 из 3
    • Pull the needle through the bottom layer of material.
    • Pull the thread taut.
  3. How to Sew a Whip Stitch: шаг 3, изображение 1 из 3 How to Sew a Whip Stitch: шаг 3, изображение 2 из 3 How to Sew a Whip Stitch: шаг 3, изображение 3 из 3
    • Drive the needle down through the top and bottom layers of fabric, close to where the needle came up.
    • The distance between where the needle comes up and goes down will be your stitch length. The smaller the stitch length, the more stitches required—and the stronger the seam.
    • Pull the thread taut on the backside of the bottom material.
  4. How to Sew a Whip Stitch: шаг 4, изображение 1 из 2 How to Sew a Whip Stitch: шаг 4, изображение 2 из 2
    • Continue bringing the needle up and down through both layers of fabric, as in steps 2 and 3 of this guide, working your way around the material.
    • If you are using this stitch as a repair where a stitch already exists, be sure to overlap the existing stitching by several stitches to help prevent it from unraveling.
  5. How to Sew a Whip Stitch: шаг 5, изображение 1 из 2 How to Sew a Whip Stitch: шаг 5, изображение 2 из 2
    • For the final stitch, come up from the back of the bottom material once again.
    • Draw the needle between the two layers of material through the stitch closest to where the needle came up.
  6. How to Sew a Whip Stitch: шаг 6, изображение 1 из 3 How to Sew a Whip Stitch: шаг 6, изображение 2 из 3 How to Sew a Whip Stitch: шаг 6, изображение 3 из 3
    • Slowly start to pull the thread taut. As you pull, you will see a loop form.
    • Draw the needle through the loop.
    • Pull the thread taut, forming a knot.
    • Repeat the process of driving the needle up from behind, drawing it through the stitch, and pulling it through the loop as described in steps 5 and 6 of this guide one more time.
  7. How to Sew a Whip Stitch: шаг 7, изображение 1 из 1
    • Ensure that the stitches are tight.
    • Cut any remaining thread, and admire your handiwork.
Финишная прямая
20 человек успешно провели ремонт по этому руководству.
Brittany McCrigler
Участник с: 03/05/12
90 418 Репутация
Автор 142 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 13
За последние 7 дней: 62
За последние 30 дней: 184
За всё время: 42,116
