Введение
If your lawn mower has stopped cutting like it once did, you might need to follow this guide. You can remove your lawn mower blade and sharpen it within 15 minutes.
Cutting grass with dull blades is inefficient and can lead to lawn disease, discoloration or portions of the grass dying.
As with anything sharp, use caution when performing this guide to avoid injury and follow all safety procedures. Also, before starting this guide, be sure to remove the spark plug to ensure that the machine does not turn on during the repair.
Выберете то, что вам нужно
Sharpen the blade with a file or with a grinder. Follow the angle that is already established and move the file along until the edge becomes sharp.
Put the blade back onto the lawn mower and screw the bolt back on while safely securing the blade.
Flip the lawn mower back to the upright position and remove the saran wrap from the gas cap.
Plug the spark plug wire in until you hear a click.
Еще один человек закончил это руководство.
